DARE!! Instruments RadiField RFS1003B
The DARE!! Instruments RadiField RFS1003B device driver is a AmplifierCouplerPower MeterAntenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Instruments RadiField RFS1003B:
The frequency range of the DARE!! Instruments RadiField RFS1003B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the DARE!! Instruments RadiField RFS1003B.
Be careful changing these settings as RadiMation® is no longer able to verify if the DARE!! Instruments RadiField RFS1003B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
There are several methods in which the DARE!! Instruments RadiField RFS1003B can be connected to the PC. The DARE!! Instruments RadiField RFS1003B can for example be connected directly to the PC, or through a plugincard in a RadiCentre 1 or a multi-slot RadiCentre. More information on how to use the RadiCentre is present in the product manual of the RadiCentre. The settings on the RadiCentre tab can be used to specify how the DARE!! Instruments RadiField RFS1003B is connected.
When the DARE!! Instruments RadiField RFS1003B is connected to a multi-slot RadiCentre, also the slot number in which the plugincard is fitted, should be specified.
ScreenElementDescription.svg Directly to PC Specifies that the DARE!! Instruments RadiField RFS1003B is connected directly to the PC, without the use of a RadiCentre.
ScreenElementDescription.svg RadiCentre 1 Specifies that the DARE!! Instruments RadiField RFS1003B is connected to a plugincard that is fitted in a RadiCentre 1.
ScreenElementDescription.svg RadiCentre multi-slot Specifies that the DARE!! Instruments RadiField RFS1003B is connected to a plugincard that is fitted in a multi-slot RadiCentre that also can be manually controlled using the display on the front of the RadiCentre. The slot number in which the plugin card is mounted can also be selected.
ScreenElementDescription.svg RadiCentre multi-slot Ultra Specifies that the DARE!! Instruments RadiField RFS1003B is connected to a plugincard that is fitted in a multi-slot RadiCentre Ultra. This RadiCentre Ultra has no display, and can only be used when remote controlled.
The configuration on the Communication tab should be configured depending on the outgoing connection from the PC. Thus if Directly to PC is selected, the communication settings should be configured as what is actually used between the PC and the DARE!! Instruments RadiField RFS1003B itself. If RadiCentre 1, RadiCentre multi-slot or RadiCentre multi-slot Ultra is selected, the communication settings should be configured as what is actually used between the PC and the RadiCentre. In the configuration where a RadiPower is connected with USB to a multi-slot RadiCentre, which is connected by GPIB to the PC, the communication settings of the RadiPower device driver should thus be GPIB.
If the DARE!! Instruments RadiField RFS1003B is for example connected to slot 3 of a multi-slot RadiCentre which has IP address 192.168.178.95 and is connected by LAN to the PC, the following settings should be configured in the device driver of the DARE!! Instruments RadiField RFS1003B:
  • RadiCentre tab
  • Communication tab
    • Communication Stream: VISA
    • LAN: 192.168.178.95
The Firmware update tab can be used to update the firmware of the DARE!! Instruments RadiField RFS1003B.
Warning: The firmware update can take a few minutes. During the actual firmware update the window is disabled, and cannot be closed. It is possible that Microsoft Windows shows messages that the RadiMation® software is not responding. Ignore those messages and do not kill, abort or end the software. Also do not disconnect the connection between the DARE!! Instruments RadiField RFS1003B and the PC, while the firmware update is being performed.
