Delphi AR 750HB Conducted Imm.
The Delphi AR 750HB Conducted Imm. device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Delphi AR 750HB Conducted Imm.:
The frequency range of the Delphi AR 750HB Conducted Imm. as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Delphi AR 750HB Conducted Imm..
Be careful changing these settings as RadiMation® is no longer able to verify if the Delphi AR 750HB Conducted Imm. is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Delphi AR 750HB Conducted Imm.
- Google image search: Delphi AR 750HB Conducted Imm.
