DeviceDriverGenericConfigurationSignalGenerator
Note: This page is used to show the configuration that is generic for all signal generator device drivers. This page will automatically be embedded on all signal generator device driver pages.
The following tabs are available in the advanced configuration of the DeviceDriverGenericConfigurationSignalGenerator:
The frequency range of the DeviceDriverGenericConfigurationSignalGenerator as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the DeviceDriverGenericConfigurationSignalGenerator.
Be careful changing these settings as RadiMation® is no longer able to verify if the DeviceDriverGenericConfigurationSignalGenerator is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
