Exodus advanced communications AMP2108BDB Refl
The Exodus advanced communications AMP2108BDB Refl device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Exodus advanced communications AMP2108BDB Refl:
The frequency range of the Exodus advanced communications AMP2108BDB Refl as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Exodus advanced communications AMP2108BDB Refl.
Be careful changing these settings as RadiMation® is no longer able to verify if the Exodus advanced communications AMP2108BDB Refl is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
