Exodus advanced communications AMP2108EDB Refl
The Exodus advanced communications AMP2108EDB Refl device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Exodus advanced communications AMP2108EDB Refl:
The frequency range of the Exodus advanced communications AMP2108EDB Refl as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Exodus advanced communications AMP2108EDB Refl.
Be careful changing these setting as RadiMation® is no longer able to verify if the Exodus advanced communications AMP2108EDB Refl is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Exodus advanced communications AMP2108EDB Refl
- Google image search: Exodus advanced communications AMP2108EDB Refl
