Frankonia VLH-500B1
The Frankonia VLH-500B1 device driver is a Amplifier, Coupler, Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia VLH-500B1:
The frequency range of the Frankonia VLH-500B1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Frankonia VLH-500B1.
Be careful changing these setting as RadiMation® is no longer able to verify if the Frankonia VLH-500B1 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Frankonia VLH-500B1
- Google image search: Frankonia VLH-500B1
