GAUSS INSTRUMENTS TDEMI X1
The GAUSS INSTRUMENTS TDEMI X1 device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the GAUSS INSTRUMENTS TDEMI X1:
The frequency range of the GAUSS INSTRUMENTS TDEMI X1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the GAUSS INSTRUMENTS TDEMI X1.
Be careful changing these settings as RadiMation® is no longer able to verify if the GAUSS INSTRUMENTS TDEMI X1 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Spectrogram mode / Receiver mode[edit]
The RadiMation® device driver for the GAUSS INSTRUMENTS TDEMI X1 is available in two different variants. The "(Spectrogram mode)" driver is using the 'Spectrogram' mode of the GAUSS INSTRUMENTS TDEMI. The other driver, without any additional prefix, is using the 'Receiver' mode of the GAUSS INSTRUMENTS TDEMI.
See the user manual of the GAUSS INSTRUMENTS TDEMI for the differences between these modes, including their benefits and disadvantages. Depending on the requirements of the test that should be performed, one or the other device driver can be used.
TCPIP Connection[edit]
  • For the TCPIP-stream the correct connection string is: tcpip://<IP-ADDRESS>:21683 (where <IP-ADDRESS> is the network IP address and 21683 is the default port of the TDEMI).
  • For the VISA-stream the correct connection string for the Visa-ID is: TCPIP::<IP-ADDRESS>::21683::SOCKET (where <IP-ADDRESS> is the network IP address and 21683 is the default port of the TDEMI).
Auto step frequency[edit]
When 'Auto step frequency' is selected in RadiMation®, the device driver for the TDEMI will select half of the selected RBW bandwidth, and will configure that in the TDEMI. Thus a 1 MHz RBW will result in an auto step frequency of 500 kHz.
Frequency Bands[edit]
The CISPR tab of the GAUSS INSTRUMENTS TDEMI X1 allows to configure if the CISPR or non-CISPR detectors should be used during the measurements.
ScreenElementDescription.svg Use CISPR detector Average (if applicable) If the checkbox is checked, the CISPR Average (indicated as the 'CAV' detector) will be used during the measurements. If the checkbox is not checked, the standard Average detector will be used.
ScreenElementDescription.svg Use CISPR detector RMS (if applicable) If the checkbox is checked, the CISPR RMS (indicated as the 'CRMS' detector) will be used during the measurements. If the checkbox is not checked, the standard RMS detector will be used.
On the Preselector tab, it can be selected if the preselector should be activated or not deactivated when the device driver of the GAUSS INSTRUMENTS TDEMI X1 is being used.
ScreenElementDescription.svg Enable preselector If the preselector should be activated, or not.
The Options tab of the GAUSS INSTRUMENTS TDEMI X1 allows to configure specific options of the GAUSS INSTRUMENTS TDEMI X1 device driver.
ScreenElementDescription.svg Enable multisampling Multisampling performs measurements with extremely low spurious levels. The GAUSS INSTRUMENTS TDEMI X1 will internally perform two scans, with different sampling frequencies. This option is only available in receiver mode driver.
ScreenElementDescription.svg Enable multichannel during pre-scan Specifies if the multichannel mode should be used during pre-scan measurements. When multichannel is activated, the GAUSS INSTRUMENTS TDEMI X1 will use parallel measurement of the frequency range using FFT-based filter banks. This option is only available in receiver mode driver.
ScreenElementDescription.svg Enable multichannel during final measurement Specifies if the multichannel mode should be used during the final measurements. When multichannel is activated, the GAUSS INSTRUMENTS TDEMI X1 will use parallel measurement of the frequency range using FFT-based filter banks. This option is only available in receiver mode driver.
More specific details of the functionality and benefits of multisampling and multichannel is described in the user manual of the GAUSS INSTRUMENTS TDEMI.
