Hewlett Packard 8546A
The Hewlett Packard 8546A device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 8546A:
The frequency range of the Hewlett Packard 8546A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Hewlett Packard 8546A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Hewlett Packard 8546A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
