IFI SMC 100 Reflected
The IFI SMC 100 Reflected device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the IFI SMC 100 Reflected:
The frequency range of the IFI SMC 100 Reflected as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the IFI SMC 100 Reflected.
Be careful changing these settings as RadiMation® is no longer able to verify if the IFI SMC 100 Reflected is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
