LadyBug LB480A
Contents
Installation instruction for the LadyBug LB480A Power meter
Install the driver package
- Download the drivers (Contents of USB Memory Stick shipped with sensors V4.5) here: https://www.ladybug-tech.com/LBResources.html
- Unzip the zip file
- Run the setup.exe and follow the setup instructions.
Additional needed files
When the setup process is complete, download the following package:
- https://www.ladybug-tech.com/downloads/software/32_64_Solution/LB3264-v1.0&v1.1.zip
- Unzip the contents
- Go into the directory "Sockets_v1.0-1.1"
- Unzip "Sockets_v1.1.zip"
- Go into the folder "Sockets_v1.1\Bridge_32_64_v1.1\Sockets_32_64_v1.1\SocketsUnsigned\necessities_v1.1\
- Verify that this folder contains "LB_SocketServer.exe" and "LB_API2_32_64.dll".
- Create a directory "C:\ladybug necessities\"
- Copy all files from "necessities_v1.1" to "C:\ladybug necessities\"
Configure RadiMation driver
In the advanced configuration in the LadyBug RadiMation driver it is needed to configure the Serial number. This number can be found on the device itself below the USB port, and is a 6 digit number.
The LadyBug LB480A device driver is a Power Meter which is supported by RadiMation®.
- Google search: LadyBug LB480A
- Google image search: LadyBug LB480A
