Mini-Circuits PWR-SEN-6LRMS-RC
The Mini-Circuits PWR-SEN-6LRMS-RC device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Mini-Circuits PWR-SEN-6LRMS-RC:
The frequency range of the Mini-Circuits PWR-SEN-6LRMS-RC as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Mini-Circuits PWR-SEN-6LRMS-RC.
Be careful changing these settings as RadiMation® is no longer able to verify if the Mini-Circuits PWR-SEN-6LRMS-RC is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Configuration of the serial number[edit]
To use the power meter the serial number needs to be configured.
- Find the serial number of the power meter.
- Start RadiMation
- Go to: Configuration > Configuration > Device drivers > Powermeters
- Select the Mini-Circuits PWR-SEN-6LRMS-RC device driver, and press on 'Edit'.
- Press the 'Shift' key on the keyboard and keep it pressed while you click with the mouse on the 'Advanced' button.
- A Notepad window will appear. Find the part that shows something like:
[MiniCircuits_PM] SerialNumber=11705140080
- Change the 'SerialNumber=' line to include the serial number of the Mini-Circuits PWR-SEN-6LRMS-RC
- Save and close the notepad file.
RadiMation should now be able to use the power meter.
