Prana N-LT 500DC
The Prana N-LT 500DC device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Prana N-LT 500DC:
The frequency range of the Prana N-LT 500DC as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Prana N-LT 500DC.
Be careful changing these settings as RadiMation® is no longer able to verify if the Prana N-LT 500DC is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
