RadiMation Error: 536871955
Calibration Files do not use the same antenna polarization
This error is raised in the configuration window of the Uniform Field Area calculation, if a calibration file is selected that does have a different antenna polarization then another selected calibration file.
It is a requirement of the Uniform Field Area calculation of RadiMation® that the antenna polarization in all the selected calibration files is the same.
This error is most often triggered as a result of not correctly selecting the correct calibration file.
Solution
  • Select the correct calibration file.
  • Select another calibration file.
  • Investigate the event-log of the selected calibration file, to see if errors have occurred during the calibration.
  • Perform the calibration again.
