RadiMation Error: 536872013
Calibration files '<CAL FILE 1>'and '<CAL FILE 2>' do not have the same frequency points[edit]
This error is raised in the configuration window of the Uniform Field Area calculation, if a calibration file is selected that does not have the same calibrated frequencies as another calibration file. The names <CAL FILE 1> and <CAL FILE 2>, show the exact names of the calibration files in which the different frequencies where found.
It is a requirement of the Uniform Field Area calculation of RadiMation® that the calibrated frequencies in all the selected calibration files are exactly the same. The same start frequency, stop frequency and step frequency should be used.
This error is most often triggered as a result of not correctly selecting the correct calibration file.
Solution[edit]
  • Select the correct calibration file.
  • Select another calibration file.
  • Investigate the event-log of the selected calibration file, to see if errors have occurred during the calibration.
  • Perform the calibration again.
