RadiMation Error: 805306571
Device Driver Function Not Implemented[edit]
RadiMation® has called a function in a device driver, however that function is not implemented in the device driver. This can occur if a newer RadiMation® software version is used in combination with an older device driver. It is also possible that the programmer of device driver has forgotten to implement the necessary function.
Solution[edit]
  • Update to the latest version of the device drivers.
  • If the same error is present in the latests version of the device driver: Contact your reseller or radimation-support@raditeq.com to resolve the error in the device driver. Please report the following information:
    • Used RadiMation® version
    • Test that is performed, including all the settings in the TSF file that are used
    • The device that is being controlled
    • NI-Spy file capture
