The Raditeq RPR4006R device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Raditeq RPR4006R:
Pre Wait Time
Wait time before starting the measurement-loop. Can be used to wait for a signal generator, and or amplifier to stabilize.
Measure
The minimum amount of measurements in the measure loop. Continues to loop even if power level is stable.
Wait Time
The wait time between each measurement is taken, during the measurement-loop.
Max. Difference
If the measured power between each measurement in the measurement-loop, is less than this value. The measured power is stable. The measurement-loop will then stop.
Max. Measure
The maximum amount of measure times, for the measurement-loop
Both for the leveling, and the monitoring these settings can be set individually.
The leveling is used, whenever RadiMation® is measuring the power, to regulate the signal generator.
If the powermeter is only used as input, without regulating on it, then the monitoring settings are used.
The frequency range of the Raditeq RPR4006R as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Raditeq RPR4006R.
Use default start frequency
Custom start frequency
Use default stop frequency
Custom stop frequency
Be careful changing these settings as RadiMation® is no longer able to verify if the Raditeq RPR4006R is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Signal generator frequency
Selects that the actual carrier frequency of the signal generator is communicated to the measurement device. This is the default behaviour.
Fixed reference frequency
Selects that a fixed frequency (independent of the signal generator carrier frequency) is communicated to the measurement device.
Signal generator frequency offset
An additional offset frequency specified in MHz, that is added to frequency that is communicated to the measurement device. This value can be positive or negative, and defaults to 0.0 MHz.
Specific reference frequency
The fixed reference frequency specified in MHz that is communicated to the measurement device, when the Fixed reference frequency option is selected.
Warning:
When a different reference frequency is specified and communicated to the measurement device, it is only relevant for the measurement device. A correction file that is attached to the device driver in RadiMation® will still use the correction value that is specified for the actual signal generator carrier frequency.
Value
Allows to select the filter that should be used in the measurement device. The possible filters are described in the manual of the Raditeq RPR4006R.
Communication Streams
Expected response
The expected *IDN? response of a device. It can be changed in the case the commands are the same for another device for which no RadiMation® driver is available yet.
Restore default
Restores the original Exepected response.
There are several methods in which the Raditeq RPR4006R can be connected to the PC. The Raditeq RPR4006R can for example be connected directly to the PC, or through a plugincard in a RadiCentre 1 or a multi-slot RadiCentre. More information on how to use the RadiCentre is present in the product manual of the RadiCentre. The settings on the RadiCentre tab can be used to specify how the Raditeq RPR4006R is connected.
When the Raditeq RPR4006R is connected to a multi-slot RadiCentre, also the slot number in which the plugincard is fitted, should be specified.
Directly to PC
Specifies that the Raditeq RPR4006R is connected directly to the PC, without the use of a RadiCentre.
RadiCentre 1
Specifies that the Raditeq RPR4006R is connected to a plugincard that is fitted in a RadiCentre 1.
RadiCentre multi-slot
Specifies that the Raditeq RPR4006R is connected to a plugincard that is fitted in a multi-slot RadiCentre that also can be manually controlled using the display on the front of the RadiCentre. The slot number in which the plugin card is mounted can also be selected.
RadiCentre multi-slot Ultra
Specifies that the Raditeq RPR4006R is connected to a plugincard that is fitted in a multi-slot RadiCentre Ultra. This RadiCentre Ultra has no display, and can only be used when remote controlled.
The configuration on the Communication tab should be configured depending on the outgoing connection from the PC. Thus if Directly to PC is selected, the communication settings should be configured as what is actually used between the PC and the Raditeq RPR4006R itself. If RadiCentre 1, RadiCentre multi-slot or RadiCentre multi-slot Ultra is selected, the communication settings should be configured as what is actually used between the PC and the RadiCentre. In the configuration where a RadiPower is connected with USB to a multi-slot RadiCentre, which is connected by GPIB to the PC, the communication settings of the RadiPower device driver should thus be GPIB.
If the Raditeq RPR4006R is for example connected to slot 3 of a multi-slot RadiCentre which has IP address 192.168.178.95 and is connected by LAN to the PC, the following settings should be configured in the device driver of the Raditeq RPR4006R:
- RadiCentre tab
- Communication tab
- Communication Stream: VISA
- LAN: 192.168.178.95
The Firmware update tab can be used to update the firmware of the Raditeq RPR4006R.
Firmware
Specifies the filename of the firmware update file that should be used to update the firmware of the measurement device.
Browse
Allows to select the firmware update file.
Update firmware
Starts the actual firmware update. First some checks are performed, and if those checks are successful, the actual firmware update is performed.
Status
Shows a message during the firmware update, indicating the performed action and the actual status.
Warning:
The firmware update can take a few minutes. During the actual firmware update the window is disabled, and cannot be closed. It is possible that Microsoft Windows shows messages that the RadiMation® software is not responding. Ignore those messages and do not kill, abort or end the software. Also do not disconnect the connection between the Raditeq RPR4006R and the PC, while the firmware update is being performed.
