Release Notes 2025.1
We are proud to deliver you Version 2025.1 of our RadiMation® EMC Test software. This 2025.1 version is the result of several major improvements that we have done.
This letter contains all the information that is needed before your system is upgraded. If you have any additional questions or remarks please let us know through your reseller, or contact radimation-support@raditeq.com.
Installation[edit]
Backup[edit]
- Correction files
- TSF files
- Sequence files
- Limit Line files
Be advised that:
Installation[edit]
Updating device drivers[edit]
Solved items[edit]
See below the list of all the issues that have been solved in RadiMation® version 2025.1 since version 2024.2
RadiMation version 2025.1.1[edit]
New functionality[edit]
- #9490: Double clicking on the name of a graph element in the legend of a multiband graph shows the graph customization for the element
- #10299: A minimum RBW of 1 Hz can now be selected
- #15725: A minimum RBW of 1 Hz can now be selected
- #13774: Correction files can be dragged to the correction file list of the device driver settings
- #13774: Directories can be dragged to the Directory configuration within the configuration
- #15610: Files can be dragged to the Template and Report configurations for EUTs (under the Reports tab).
Solved items[edit]
- #13086: The reveal buttons (with a magnifying glass symbol) in the list of correction files for a device driver now correctly show as enabled when a file is selected.
- #15635: It is now possible to highlight a graph element by clicking its name in the legend. This emphasizes the element by drawing it thicker and drawing other elements with increased transparency. Each of these behaviours can be individually controlled in the advanced settings.
Known Problems[edit]
- Open the configuration window of RadiMation®
- Select the Device Drivers tab
- Select Receivers/Spectrum Analysers
- Select the R&S receiver
- Press Edit to open the device driver configuration window
- Press the Advanced button
- The GPIB configuration dialog of the R&S device driver will be shown
- Activate the Show advanced Settings checkbox
- The GPIB Configuration dialog will show a Wait time box
- Specify 3000 us in the Wait time box
