The Rohde & Schwarz ESI 26 Input 1 device driver is a Power Meter, Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESI 26 Input 1:
Pre Wait Time
Wait time before starting the measurement-loop. Can be used to wait for a signal generator, and or amplifier to stabilize.
Measure
The minimum amount of measurements in the measure loop. Continues to loop even if power level is stable.
Wait Time
The wait time between each measurement is taken, during the measurement-loop.
Max. Difference
If the measured power between each measurement in the measurement-loop, is less than this value. The measured power is stable. The measurement-loop will then stop.
Max. Measure
The maximum amount of measure times, for the measurement-loop
Both for the leveling, and the monitoring these settings can be set individually.
The leveling is used, whenever RadiMation® is measuring the power, to regulate the signal generator.
If the powermeter is only used as input, without regulating on it, then the monitoring settings are used.
The frequency range of the Rohde & Schwarz ESI 26 Input 1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz ESI 26 Input 1.
Use default start frequency
Custom start frequency
Use default stop frequency
Custom stop frequency
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz ESI 26 Input 1 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Signal generator frequency
Selects that the actual carrier frequency of the signal generator is communicated to the measurement device. This is the default behaviour.
Fixed reference frequency
Selects that a fixed frequency (independent of the signal generator carrier frequency) is communicated to the measurement device.
Signal generator frequency offset
An additional offset frequency specified in MHz, that is added to frequency that is communicated to the measurement device. This value can be positive or negative, and defaults to 0.0 MHz.
Specific reference frequency
The fixed reference frequency specified in MHz that is communicated to the measurement device, when the Fixed reference frequency option is selected.
Warning:
When a different reference frequency is specified and communicated to the measurement device, it is only relevant for the measurement device. A correction file that is attached to the device driver in RadiMation® will still use the correction value that is specified for the actual signal generator carrier frequency.
