Rohde & Schwarz ESR 26
The Rohde & Schwarz ESR 26 device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESR 26:
The frequency range of the Rohde & Schwarz ESR 26 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz ESR 26.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz ESR 26 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
