Rohde & Schwarz FPC1000
The Rohde & Schwarz FPC1000 device driver is a Power Meter, Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz FPC1000:
The frequency range of the Rohde & Schwarz FPC1000 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz FPC1000.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz FPC1000 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
An additional offset frequency specified in MHz, that is added to frequency that is communicated to the measurement device. This value can be positive or negative, and defaults to 0.0 MHz. |
RBW selection[edit]
This device supports a different maximum allowed RBW in analyzer mode(3 MHz) and receiver mode(1 MHz).
If AUTO RBW is selected this could thus result in a big difference in the AUTO determined RBW values used during the pre-scan and final measurement.
Different RBW values will result in different measurement results.
