Rohde & Schwarz FSH 6
The Rohde & Schwarz FSH 6 device driver is a Signal GeneratorPower MeterField SensorSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz FSH 6:
The frequency range of the Rohde & Schwarz FSH 6 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz FSH 6.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz FSH 6 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
ScreenElementDescription.svg Measure The minimum amount of measurements in the measure loop. Continues to loop even if field strength level is stable.
ScreenElementDescription.svg Max. Difference If the measured field strength between each measurement in the measurement-loop, is less than this value. The measured field strength is stable. The measurement-loop will then stop.
