Rohde & Schwarz NRP-Z22
The Rohde & Schwarz NRP-Z22 device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz NRP-Z22:
The frequency range of the Rohde & Schwarz NRP-Z22 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz NRP-Z22.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz NRP-Z22 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Rohde & Schwarz NRP-Z22 Notes[edit]
- The RadiMation® device driver can only be used if the program NRPView, 1.0.27 or above, from Rohde & Schwarz is installed. When installing the program make sure that you install all the items. If not all items are installed, some required DLL's are not installed.
- Setting the resolution higher will make the measurement slower because the power meter is taking more samples and perform an average over the samples. This is done dynamically depending on the power measured.
- The syntax for the Instrument Descriptor is as follows:
USB::<vendor Id>::<product Id>::<serial number>, where:- <vendor Id> is 0AAD for Rohde&Schwarz
- <product Id> depends on the sensor
- <serial number> you can find on your sensor. Serial number is a number with 6 digits. For example: 900003
The <product Id> is depending on the specific model of the powerhead, and can be looked up from the table:
| Powerhead model | <product Id> |
| NRP-Z21 | 0x0003 |
| NRP-FU | 0x0004 |
| FSH-Z1 | 0x000B |
| NRP-Z11 | 0x000C |
| NRP-Z22 | 0x0013 |
| NRP-Z23 | 0x0014 |
| NRP-Z24 | 0x0015 |
| NRP-Z51 | 0x0016 |
| NRP-Z52 | 0x0017 |
| NRP-Z55 | 0x0018 |
| NRP-Z56 | 0x0019 |
| FSH-Z18 | 0x001A |
| NRP-Z91 | 0x0021 |
| NRP-Z81 | 0x0023 |
| NRP-Z31 | 0x002C |
| NRP-Z37 | 0x002D |
| NRP-Z96 | 0x002E |
| NRP-Z27 | 0x002F |
| NRP-Z28 | 0x0051 |
| NRP-Z98 | 0x0052 |
| NRP-Z92 | 0x0062 |
| NRP-Z57 | 0x0070 |
| NRP-Z85 | 0x0083 |
| NRPC40 | 0x008F |
| NRPC50 | 0x0090 |
| NRP-Z86 | 0x0095 |
| NRP-Z41 | 0x0096 |
| NRP-Z61 | 0x0097 |
| NRP-Z71 | 0x0098 |
| NRP-Z32 | 0x009A |
| NRP-Z211 | 0x00A6 |
| NRP-Z221 | 0x00A7 |
| NRP-Z58 | 0x00A8 |
| NRPC33 | 0x00B6 |
| NRPC18 | 0x00Bf |
| NRPC18-B1 | 0x00C1 |
| NRPC33-B1 | 0x00C2 |
| NRPC40-B1 | 0x00C3 |
| NRPC50-B1 | 0x00C4 |
| NRP8S | 0x00E2 |
| NRP8SN | 0x0137 |
| NRP18S | 0x0138 |
| NRP18SN | 0x0139 |
| NRP33S | 0x0145 |
| NRP33SN | 0x0146 |
| NRP18S-10 | 0x0148 |
| NRP18SN-10 | 0x0149 |
| NRP18S-20 | 0x014A |
| NRP18SN-20 | 0x014B |
| NRP18S-25 | 0x014C |
| NRP18SN-25 | 0x014D |
| NRP18A | 0x014E |
| NRP18AN | 0x014F |
| NRP18T | 0x0150 |
| NRP18TN | 0x0151 |
| NRP33T | 0x0152 |
| NRP33TN | 0x0153 |
| NRP40T | 0x0154 |
| NRP40TN | 0x0155 |
| NRP50T | 0x0156 |
| NRP50TN | 0x0157 |
| NRP67T | 0x0158 |
| NRP67TN | 0x0159 |
| NRP110T | 0x015A |
| NRP40S | 0x015F |
| NRP40SN | 0x0160 |
| NRP50S | 0x0161 |
| NRP50SN | 0x0162 |
| NRP33SN-V | 0x0168 |
| NRP6A | 0x0178 |
| NRP6AN | 0x0179 |
| NRPM3 | 0x0195 |
Examples: "USB::0x0AAD::0x000B::900003"
You can use '*' for <product Id> or <serial number>. It is however suggested to use fully qualified resource descriptors, when more than one sensor is connected. The asterisk placeholder, can only be used when only one single sensor is connected.
Examples:
- "USB::0x0AAD::0x000C::*" - Opens first NRP-Z11 sensor on the USB bus
- "USB::0x0AAD::*" - Opens first R&S sensor on the USB bus
- "*" - Opens first R&S sensor on the USB bus
Related RadiMation errors[edit]
- RadiMation Error: -1074001424: "Instrument status error". This error is raised when a zero is performed on the power meter, and too much power is present during the zero operation. In this case, decrease the applied power and perform the zero operation again.
Installation[edit]
Please go the official website of the manufacturer Rohde & Schwarz and go to the page of your R&S®NRP Average Power Sensor model.
Apparently the required component for this driver is the R&S® NRP-Toolkit.
Install the R&S NRP-toolkit for Windows: https://www.rohde-schwarz.com/software/nrp-z2x1/?facet=facet.SoftwareType&facet.SoftwareType=Tools
