Rohde & Schwarz NRP18AN
The Rohde & Schwarz NRP18AN device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz NRP18AN:
The frequency range of the Rohde & Schwarz NRP18AN as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz NRP18AN.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz NRP18AN is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
