Rohde & Schwarz NRP (SMB 100A)
The Rohde & Schwarz NRP (SMB 100A) device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz NRP (SMB 100A):
The frequency range of the Rohde & Schwarz NRP (SMB 100A) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz NRP (SMB 100A).
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz NRP (SMB 100A) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
Configuration of the NRP connected to the SMB generator[edit]
Ensure that the power meter that you are trying to control is mapped to an index on the generator "See the NRP Sensor Mapping configuration on the generator." section in the manual or find the following direct link to the online manual of the device: https://www.rohde-schwarz.com/webhelp/smb100a_html_usermanual_1/Content/92d52ebbb9964baa.htm
Ensure that the corresponding channel index is also configured in the advanced settings of the RadiMation signal generator device driver.
