Rohde & Schwarz NRP (SMB 100B)
The Rohde & Schwarz NRP (SMB 100B) device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz NRP (SMB 100B):
The frequency range of the Rohde & Schwarz NRP (SMB 100B) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz NRP (SMB 100B).
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz NRP (SMB 100B) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
An additional offset frequency specified in MHz, that is added to frequency that is communicated to the measurement device. This value can be positive or negative, and defaults to 0.0 MHz. |
Configuration of the NRP connected to the SMB generator[edit]
Ensure that the power meter that you are trying to control is mapped to an index on the generator "See the NRP Sensor Mapping configuration on the generator." section in the manual or find the following direct link to the online manual of the device: https://www.rohde-schwarz.com/webhelp/smb100a_html_usermanual_1/Content/92d52ebbb9964baa.htm
Ensure that the corresponding channel index is also configured in the advanced settings of the RadiMation signal generator device driver.
