Rohde & Schwarz NRVD Channel A
The Rohde & Schwarz NRVD Channel A device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz NRVD Channel A:
The frequency range of the Rohde & Schwarz NRVD Channel A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz NRVD Channel A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz NRVD Channel A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
The following tabs are available in the advanced configuration of the Rohde & Schwarz NRVD Channel A.
ScreenElementDescription.svg Enable internal frequency correction Will enable the internal frequency correction of the power meter.
ScreenElementDescription.svg Filter setting Selects the filter that should be used during the power measurement. Refer to the manual because the measure time is depending on the type of power head and filter setting.
