Rohde & Schwarz NRX
The Rohde & Schwarz NRX device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz NRX:
The frequency range of the Rohde & Schwarz NRX as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz NRX.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz NRX is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Configuring the R&S NRX[edit]
GPIB usage[edit]
  1. Open the settings menu of the NRX.
  2. Open the connection settings.
  3. Select remote this shall open the following screen on the NRX.
  4. Set The GPIB adress which is configured in the communications tab of the advanced settings for the NRX.
