Rohde & Schwarz URV55
The Rohde & Schwarz URV55 device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz URV55:
The frequency range of the Rohde & Schwarz URV55 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz URV55.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz URV55 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
The URV55 is an older power meter that sometimes problems with communication. At random, but usually during the power delivery the power meter returns an error.
solution[edit]
  1. insert gpib communication, or start the NI spy program
  2. disable the power delivery test
