Rohde & Schwarz URVD Channel B
The Rohde & Schwarz URVD Channel B device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz URVD Channel B:
The frequency range of the Rohde & Schwarz URVD Channel B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz URVD Channel B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz URVD Channel B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
