Siglent Technologies SSA3021X Plus
The Siglent Technologies SSA3021X Plus device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Siglent Technologies SSA3021X Plus:
The frequency range of the Siglent Technologies SSA3021X Plus as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Siglent Technologies SSA3021X Plus.
Be careful changing these settings as RadiMation® is no longer able to verify if the Siglent Technologies SSA3021X Plus is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
