Siglent Technologies SVA1021X
The Siglent Technologies SVA1021X device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Siglent Technologies SVA1021X:
The frequency range of the Siglent Technologies SVA1021X as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Siglent Technologies SVA1021X.
Be careful changing these settings as RadiMation® is no longer able to verify if the Siglent Technologies SVA1021X is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
