Teseq ITS 6006
The Teseq ITS 6006 device driver is a Signal Generator, Power Meter, AD Converter, Switch Matrix which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq ITS 6006:
The frequency range of the Teseq ITS 6006 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Teseq ITS 6006.
Be careful changing these settings as RadiMation® is no longer able to verify if the Teseq ITS 6006 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
The USB drivers for the ITS-6006 are included in the 'ITS 6006 Tools Software (MS Windows)' and can be downloaded from: http://www.teseq.com/support/its-6006/its-6006-tools-software.php
When the RS232 connection is used, the communication settings should be set to: 115200 Baud, 8 bits, no parity, 1 stopbit. When the USB connection is used, the correct USB Virtual Comport should be selected, and the communication settings should be set to: 9600 baud, 8 bits, no parity, 1 stopbit.
These Teseq USB drivers are probably not working on Windows 10. It is advised to use Windows 7.
