Teseq NSG 4060 Signal Generator
The Teseq NSG 4060 Signal Generator device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq NSG 4060 Signal Generator:
The frequency range of the Teseq NSG 4060 Signal Generator as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Teseq NSG 4060 Signal Generator.
Be careful changing these settings as RadiMation® is no longer able to verify if the Teseq NSG 4060 Signal Generator is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Teseq NSG 4060 Signal Generator
- Google image search: Teseq NSG 4060 Signal Generator
