Teseq NSG 4070-45
The Teseq NSG 4070-45 device driver is a Signal GeneratorAmplifierCouplerPower Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq NSG 4070-45:
The frequency range of the Teseq NSG 4070-45 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Teseq NSG 4070-45.
Be careful changing these settings as RadiMation® is no longer able to verify if the Teseq NSG 4070-45 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
How to install and connect a NSG 4070-45 to Radimation over USB.[edit]
  • Make sure that the device is set to USB. You can find this via the setup button on the device itself. Please reerence te manual from Teseq for further information.
  • Connect the device physically via USB.
  • Open device manager (Type device manager in the search window next to start in windows)
  • Open your com ports and look for the name NSG 4070 (The picture above is a example. When the NSG4070 is present and recognised a com port with the name NSG 4070 should be visible here. If not please reference the manual from the device)
  • Check which com port this is
  • Open Radimation
  • Go to configuration/configuration/device drivers/amplifiers
  • Add the driver for the NSG4070 by clicking add
  • Open the settings by double clicking
  • Click "advanced"
  • Go to the tab "communication"
  • Set "Communication streams" to: RS232
  • Set the COM port to the number that you have found in device manager from Windows
  • Set the Baud rate to 9600 baud !! (this is important, it is not in the documentation of the manufacturer. If you want to use the USB connection then it's communication is using RS-232 with a fixed baud rate of 96000)
  • Leave the rest default.
  • Click "Ok" and press "Check"
  • If all was set correctly you will receive a message that the communication was successful. The amplifier is now configured and ready for use in the software
