Teseq PMU 6003
The Teseq PMU 6003 device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq PMU 6003:
The frequency range of the Teseq PMU 6003 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Teseq PMU 6003.
Be careful changing these settings as RadiMation® is no longer able to verify if the Teseq PMU 6003 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
The USB drivers for the PM(U)-6003 are included in the 'PM 600x Tools Software (MS Windows)' and can be downloaded from: http://www.teseq.com/support/pm-600x/PM-600x-Tools-Software.php
These Teseq USB drivers are probably not working on Windows 10. It is advised to use Windows 7.
