Tests.TurnTableAngle.Physical.Maximum
This advanced option specifies the maximum angle where the turntable can turn to. RadiMation® version 5.8 will question the turntable controller it's maximum physical allowed angle. The retrieved maximum turntable controller angle and the value of Tests.TurnTableAngle.Physical.Maximum will be used to determine the maximum angle to which the turntable will be controlled. The lowest of the two values is used.
The default value of Tests.TurnTableAngle.Physical.Maximum is set to 560 degrees, which ensures that any turntable is not controlled beyond the 560 degrees. This default value is by purpose specified as a relatively large value to prevent unwanted limitations.
If (for any reason) a limitation of the turntable angle is needed smaller than the maximum physical turntable angle of the turntable controller itself, the value of Tests.TurnTableAngle.Physical.Maximum can be set to a value that is lower than the limitation in the turntable controller itself. If for example the value of Tests.TurnTableAngle.Physical.Maximum is set to 200, RadiMation® will never try to turn to an angle that is above 200 degrees.
There are other advanced options available that are related to this advanced option:
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
