Tests.TurnTableAngle.Physical.Minimum
This advanced option specifies the minimum angle where the turntable can turn to. RadiMation® version 5.8 will question the turntable controller it's minimum physical allowed angle. The retrieved minimum turntable controller angle and the value of Tests.TurnTableAngle.Physical.Minimum will be used to determine the minimum angle to which the turntable will be controlled. The highest of the two values is used.
The default value of Tests.TurnTableAngle.Physical.Minimum is set to -200 degrees, which ensures that any turntable is not controlled below the -200 degrees. This default value is by purpose specified as a relatively small value to prevent unwanted limitations.
If (for any reason) a limitation of the turntable angle is needed higher than the minimum physical turntable angle of the turntable controller itself, the value of Tests.TurnTableAngle.Physical.Minimum can be set to a value that is higher than the limitation in the turntable controller itself. If for example the value of Tests.TurnTableAngle.Physical.Minimum is set to 45, RadiMation® will never try to turn to an angle that is below 45 degrees.
There are other advanced options available that are related to this advanced option:
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
