UI.EnvironmentalData.AutoClickAllButton
This advanced option specifies if the 'Same as last test for all parameters' button on the Environmental Data window should be clicked automatically if the window is shown. If the button is clicked, all the parameters will be set to the value that was used in the last test.
Possible values for this advanced option:
- True: the button is clicked automatically when the window is shown. This will lead to the result that the values of all the parameters are already filled in with the values of the last test.
- False (Default): the button will not be clicked automatically.
There are other advanced options available that determine the look and behaviour of the environmental data window:
- UI.EnvironmentalData.ShowSameForAllButton
- UI.EnvironmentalData.CloseOnAllButtonClick
- UI.EnvironmentalData.AutoClickAllButton
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
