UI.EnvironmentalData.CloseOnAllButtonClick
This advanced option specifies if the Environmental Data window should automatically be closed if the 'Same as last test for all parameters' button is clicked.
Possible values for this advanced option:
- True: Clicking the 'Same as last test for all parameters' button, will first fill in the values of all the parameters with the values of the last test. After that the 'Ok' button will also be automatically clicked, so the window will be automatically closed.
- False (Default): Clicking the 'Same as last test for all parameters' button, will only fill in the values of all the parameters with the values of the last test.
There are other advanced options available that determine the look and behaviour of the environmental data window:
- UI.EnvironmentalData.ShowSameForAllButton
- UI.EnvironmentalData.CloseOnAllButtonClick
- UI.EnvironmentalData.AutoClickAllButton
Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
