DARE!! Instruments RadiLink 1003A
Jump to: navigation, search
The DARE!! Instruments RadiLink 1003A device driver is a Cable which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Instruments RadiLink 1003A:
The frequency range of the DARE!! Instruments RadiLink 1003A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DARE!! Instruments RadiLink 1003A.
Be careful changing these setting as RadiMation® is no longer able to verify if the DARE!! Instruments RadiLink 1003A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
