Hewlett Packard 8566B + 85685A + 85650A (Alenia R2)(10 dB)
Jump to: navigation, search
The Hewlett Packard 8566B + 85685A + 85650A (Alenia R2)(10 dB) device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 8566B + 85685A + 85650A (Alenia R2)(10 dB):
The frequency range of the Hewlett Packard 8566B + 85685A + 85650A (Alenia R2)(10 dB) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hewlett Packard 8566B + 85685A + 85650A (Alenia R2)(10 dB).
Be careful changing these setting as RadiMation® is no longer able to verify if the Hewlett Packard 8566B + 85685A + 85650A (Alenia R2)(10 dB) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
