PMM 9010 Userport Controlled LISN
The PMM 9010 Userport Controlled LISN device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the PMM 9010 Userport Controlled LISN:
The frequency range of the PMM 9010 Userport Controlled LISN as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the PMM 9010 Userport Controlled LISN.
Be careful changing these setting as RadiMation® is no longer able to verify if the PMM 9010 Userport Controlled LISN is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: PMM 9010 Userport Controlled LISN
- Google image search: PMM 9010 Userport Controlled LISN
