Rigol Technologies RSA 3030N (EMI mode)
The Rigol Technologies RSA 3030N (EMI mode) device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rigol Technologies RSA 3030N (EMI mode):
The frequency range of the Rigol Technologies RSA 3030N (EMI mode) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rigol Technologies RSA 3030N (EMI mode).
Be careful changing these setting as RadiMation® is no longer able to verify if the Rigol Technologies RSA 3030N (EMI mode) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Rigol Technologies RSA 3030N (EMI mode)
- Google image search: Rigol Technologies RSA 3030N (EMI mode)
