Tektronix RSA503A
The Tektronix RSA503A device driver is a Power Meter, Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Tektronix RSA503A:
The frequency range of the Tektronix RSA503A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Tektronix RSA503A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Tektronix RSA503A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
When the RSA_API interface is used to control the Tektronix RSA503A, it is not possible to:
- use CISPR RBW filters
- use CISPR Peak detector
- use CISPR Average detector
- use CISPR QP detector
- use CISPR RMS detector
Also a Tektronix SignalVu-PC device driver is present, which uses the Tektronix SignalVu-PC software to control the Tektronix RSA503A. That device driver is able to use the CISPR filters and detectors, however this does require that also one of the modules SVQPNL-SVPC, SVQPFL-SVPC, EMCVUNL-SVPC or EMCVUFL-SVPC is purchased.
Installation
A USB 3.0 port is required to communicate with the Tektronix RSA503A. If no USB 3.0 port is present, the device will not be working. The device doesn’t have a power on/off button. Connecting it to the USB 3.0 port will activate the device.
On a 64-bit Windows operating system, the 64-bit version of RSA_API should be installed. That installation will also include the 32-bit DLL which is available at: "C:\Tektronix\RSA_API\lib\x86\RSA_API.dll". This fixed path is also included in the RadiMation device driver, so installing it on another location could cause that no connection could be created. The driver has been created and is tested with version 3.23.0022 of the RSA_API.
The reference clock of the Tektronix RSA503A can be selected to use the internal or an externally supplied reference clock..
Internal | Use the reference clock that is internally available in the Tektronix RSA503A. |
External | Use an externally supplied reference clock. |
The scan resolution of the Tektronix RSA503A can be selected. The scan resolution is the number of points that will be present in a single sweep of the analyzer.
Scan resolution | Specify the number of points that should be used by the Tektronix RSA503A for a sweep. It may be possible to select a known value from the dropdown list. |
