Tektronix SignalVu-PC
Jump to: navigation, search
The Tektronix SignalVu-PC device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Tektronix SignalVu-PC:
The frequency range of the Tektronix SignalVu-PC as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Tektronix SignalVu-PC.
Be careful changing these setting as RadiMation® is no longer able to verify if the Tektronix SignalVu-PC is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
The Tektronix SignalVu-PC software is a software package from Tektronix that is able to control the Tektronix RSA Analyzers.
RadiMation® is able to control the Tektronix RSA Analyzers through the Tektronix RSA_API, using one of the drivers:
Another communication method is also possible where RadiMation® controls the SignalVu software, where the SignalVu software controls the actual Tektronix analyzer.
The Tektronix SignalVu-PC software is able to use the CISPR filters and detectors, however this does require that also one of the modules SVQPNL-SVPC, SVQPFL-SVPC, EMCVUNL-SVPC or EMCVUFL-SVPC is purchased.
Installation
A USB 3.0 port is required to communicate with the RSA analyzer. If no USB 3.0 port is present, the device will not be working. The device doesn’t have a power on/off button. Connecting it to the USB 3.0 port will activate the device.
The SignalVu-PC software should be installed on the machine that is connected to the RSA analyzer. Also the 'TekVISA' software should be installed to allow a connection from RadiMation® to the SignalVu software.
It is necessary to start the SignalVu software, which will automatically connect to the Tektronix RSA analyzer. Then also the 'TekVISA LAN Server Control' should be started as Administrator. Then the 'Tek VISA LAN Server Control' program is available in the notification area of windows beside the clock on the taskbar. Right clicking on the icon allows to 'Start VXI-11 Server'. RadiMation is using that VXI-11 server connection, and it should thus be running. A firewall could be blocking the connection, so it may be necessary to open any additional ports.
In the RadiMation® device driver of the Tektronix SignalVu-PC driver, in the VISA settings, the LAN address of the PC that is running the SignalVu software should be specified. This can also be 'localhost' if it is running on the same PC.
Because RadiMation® is using the VISA layer to communicate, it is also necessary to install the National Instruments VISA software.
It is also possible to control the SignalVu-PC through the socket server. If the SignalVu-PC software is controlled on the Socket server, it will be available on raw socket port 4000.
The reference clock of the Tektronix SignalVu-PC can be selected to use the internal or an externally supplied reference clock..
ScreenElementDescription.png Internal Use the reference clock that is internally available in the Tektronix SignalVu-PC.
ScreenElementDescription.png External Use an externally supplied reference clock.
The scan resolution of the Tektronix SignalVu-PC can be selected. The scan resolution is the number of points that will be present in a single sweep of the analyzer.
ScreenElementDescription.png Scan resolution Specify the number of points that should be used by the Tektronix SignalVu-PC for a sweep. It may be possible to select a known value from the dropdown list.
Manual control of SignalVu-PC
If the SignalVu software is manually controlled when a RadiMation test is also running, it could trigger a communication disconnect between RadiMation and the SignalVu software. It is therefor advised to not interact with the SignalVu software as long as RadiMation is also performing a test.
