Kalmus LA1000L Forward Power Meter
The Kalmus LA1000L Forward Power Meter device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Kalmus LA1000L Forward Power Meter:
The frequency range of the Kalmus LA1000L Forward Power Meter as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Kalmus LA1000L Forward Power Meter.
Be careful changing these settings as RadiMation® is no longer able to verify if the Kalmus LA1000L Forward Power Meter is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
