Multiband.SafeState.SignalGenerator.CarrierLevel
This advanced option specifies the level (in dBm) of the Carrier level, to which the signal generator should be set, at the end of a test (or band in a Multiband test). The default value of this option is -80.
Also see Multiband.SafeState.SignalGenerator.SetCarrierLevel, which determines if the Carrier level is changed at the end of the test. If that option is set to 'False', the carrier level of the signal generator is not changed at all at the end of a test. And also the Multiband.SafeState.SignalGenerator.UseStartingLevel option is relevant. If the Multiband.SafeState.SignalGenerator.UseStartingLevel is set, the carrier level will be set to the 'signal generator starting level', and the value of this option will then not be used.
There are other advanced options available that are related to this advanced option:
- Multiband.SafeState.SignalGenerator.SwitchCarrierOff
- Multiband.SafeState.SignalGenerator.SetCarrierLevel
- Multiband.SafeState.SignalGenerator.UseStartingLevel
- Multiband.SafeState.SignalGenerator.CarrierLevel
- Multiband.SafeState.Amplifier.SetInStandby
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
