Multiband.SafeState.SignalGenerator.UseStartingLevel
This advanced option specifies if the 'Signal generator starting level' should be set as the Carrier level of the signal generator, at the end of a test (or band in a Multiband test). The default value of this option is True, and thus the Carrier Level will be set to the 'Signal generator starting level'. If this option is not set the value that is specified in the Multiband.SafeState.SignalGenerator.CarrierLevel option will be set as the carrier level
Also see Multiband.SafeState.SignalGenerator.SetCarrierLevel, which determines if the Carrier level is changed at the end of the test. If that option is set to 'False', the carrier level of the signal generator is not changed at all at the end of a test.
This option is introduced in Version 2015.3.2 of RadiMation®, older versions do not use this advanced option and will use the Multiband.SafeState.SignalGenerator.CarrierLevel option.
There are other advanced options available that are related to this advanced option:
- Multiband.SafeState.SignalGenerator.SwitchCarrierOff
- Multiband.SafeState.SignalGenerator.SetCarrierLevel
- Multiband.SafeState.SignalGenerator.UseStartingLevel
- Multiband.SafeState.SignalGenerator.CarrierLevel
- Multiband.SafeState.Amplifier.SetInStandby
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
