Multiband.SafeState.SignalGenerator.SetCarrierLevel
This advanced option specifies if the Carrier level of the signal generator should be changed, at the end of a test (or band in a Multiband test). The default value of this option is True, and thus the Carrier level will by changed to a safe value at the end of the test..
Also see Multiband.SafeState.SignalGenerator.UseStartingLevel and Multiband.SafeState.SignalGenerator.CarrierLevel which specify the level of the carrier level that should be set at the end of a test.
There are other advanced options available that are related to this advanced option:
- Multiband.SafeState.SignalGenerator.SwitchCarrierOff
- Multiband.SafeState.SignalGenerator.SetCarrierLevel
- Multiband.SafeState.SignalGenerator.UseStartingLevel
- Multiband.SafeState.SignalGenerator.CarrierLevel
- Multiband.SafeState.Amplifier.SetInStandby
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
