RadiMation Application Note 101
Table of Contents[edit]
- Introduction
- How to perform a basic Radiated Emission test?
- How to use the Continuous Measure method?
- How to use Optimize Angle?
Step 1: Adding drivers[edit]
Device Drivers
Note: |
Additional information during this step: http://wiki.dare.nl/wiki/index.php/Chapter_2#Device_driver_configuration |
Test-Sites
Configure...
Add
Note: |
Additional information during this step: http://wiki.dare.nl/wiki/index.php/Chapter_2#Test_equipment_list_configuration |
Step 3: Create EUT[edit]
File
New
EUT
Step 4: Start new test[edit]
Tests
Radiated Emission
Multiband
New
Step 5: Configure TSF[edit]
In this application note we disable the automatic peak search and are not selecting any final detectors.
Remark: this will speed up the test, but after the pre-measurement the automatic button will therefore not trigger a final measurement.
Step 6: Save TSF[edit]
File
Save TSF
When we want to optimize the Angle around the peak, we can select the Optimize Angle Settings. Open and click the button 'Configure', this will show the following window.
Note: The configuration of this setting can be found at two locations. It can also be found (after the pre-measurement has been finished) in the Multiband Manual Mode Window. Click the button 'Peak Actions' and select 'Configure' -> 'Optimize Angle' and click. To start click again 'Peak Actions' and select 'Optimize Angle' to start optimizing the angle of the selected peaks in the table.
The above settings imply that a total area of 90 degrees will be scanned, which means half of the area left (-45 degrees) of the current peak angle and half of the area right (+45 degrees) of the current peak angle. During the optimization of the angle only the peak detector will be used during the measurements. It is possible to choose the same detector(s) as used during the pre-measurement, final measurement or a totally different detector configuration.
So, let's say that the original peak was found at 180 degrees. When the optimize angle is performed it will then measure from 135 degrees (180 - 45) until 225 degrees (180 + 45) with a step size of 30 degrees. Measurements will take place at: 135, 165, 195 and 225 degrees). With these settings it is possible to widen or narrow the area around the peak and to adjust the used amount of steps (measurements).
One of the reasons why steps are implemented - instead of a continuous measurement method - is that using fixed steps will guarantee that the measurement is performed at the stepped degrees positions, as it is no longer turning during the measurement at this position. A continuous measurement method is heavily depending on the used settings and therefore it for example unsure if the measurement is performed at a certain position (or was already moved to the next position), causing measurements errors.
How to show the graph in Polar Plot?[edit]
By default the selected tab is the frequency. Select the Polar Plot by selecting the Angle tab:
When the tab Angle is selected we can now see the Polar Plot of the Optimize Angle measurements:
Note: In this polar plot both the original as the final peak were found at 0 degree and the final measurement value was 20,2 dBuV/m.
How to use Write and Max-hold during the Continuous Measure method?[edit]
Load and start the 'Basic Emission test' TSF file.
After the pre-measurements has been finished the Multiband Manual Mode Window has a relatively large 'Continuous Measure' button at the middle right of the screen. Now, click this button and RadiMation will start taking measurement. This is a heavy process and it is normal when more CPU is used by the computer.
There are two modes during these measurements:
- Write: each new measurement will overwrite the previous measurement data.
- Max-hold: only higher new measurement values will overwrite the previous measurement data.
The results will be displayed in the frequency plot. However, when the Angle plot is selected and the turntable is manual controlled (by using the control at the left in this window) this can be seen as a manual optimize Angle method.
